Go Back   RC-Monster Forums > Support Forums > Novak
Garcol
06.16.2009, 06:40 PM
I have two HV Pro 6.5 systems, one in my E and one in my wifes E. They are very reliable and take alot of abuse. Personally i think that the MMM and the Novak run pretty close to each other in torque and speed with 4s LiPo. Yes I have two MMM one for me and one for my wife in our new ERBE's. Mine failed after 20 minutes and been running my E ever since. I run it against nitro's and ERBE's on our small neighborhood track. I still hold the fastest lap and best points with my good old faithful and dependable Emaxx/Novak. Course keep in mind it is a small track and the ERBE's cant really let loose with 6s. But I still love my Novak powered Emaxx.
Switch to Lipo batteries and get good ones, and youll be amazed at the difference. DO NOT run a MMM system on NiMh you will damage the batteries or the ESC or both.
NovakTwo
Senior Strategist
06.17.2009, 10:18 AM
Glad to hear that you are enjoying your Novak set-up.
Novak Electronics, Inc.
bcltoys
06.17.2009, 07:21 PM
Hello again can these critters be run in parallel like 2 4s packs.
Garcol
06.17.2009, 09:16 PM
I dont see why not. Just be sure your voltage is correct going into the ESC and of course be sure you have some type of low voltage control.
NovakTwo
Senior Strategist
06.18.2009, 10:06 AM
Any set-up or application questions can always be directed to tech@teamnovak.com
06.18.2009, 10:37 AM
If you plan to use the internal bec you must run a pair of 2s packs, as the bec will over heat on more than that.
Garcol
06.18.2009, 05:29 PM
Ok, well my advice wasnt really very good.
I "think" you can jumper the non BEC side and be able to run your 4s's in parallel. But you really need to check with Novak to be sure.
Sorry about that!.
bcltoys
06.18.2009, 07:01 PM
No problem with that all info is good.
