which medusa motor?
timaneli
which medusa motor? - 06.18.2009, 10:46 AM
hello.
iam almost finishing my rc8 conversion and i need a motor for this car.
i have a 150a hobbywing esc and i want a medusa motor for 4 to 6s, but mainly to run 4s lipo and to run cool at these voltage...
which medusa should i choose?
regards
you are what you race!!
06.18.2009, 10:51 AM
60mm 2000kv 4s to 1600kv 6s
timaneli
06.18.2009, 11:43 AM
is big the difference from the 2000kv for the 2200kv?
and can they handle bigger gearing without getting too much hot?
regards
06.18.2009, 12:16 PM
The 6s set up....Arct1K mentioned above is the more efficient set-up and will run cooler
glassdoctor
TEAM FUSION
glassdoctor's Avatar
06.18.2009, 12:22 PM
If you want a 4s setup... but want to run 6s to goof off, you could do the 2000kv. Several local guys are racing this motor on 4s.
Too bad they don't have an 1800... that would be even better
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
