RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.03.2006, 11:15 PM
The strobe is the ultimate slipper setup for sure. the stock setup will hold up OK as well(though you MUST have new pegs and the adjustment must be as tight as possible). If you keep melting the middle, my guess is that the 6 stock pegs are worn out and no matter how tight you try to set the slipper, you will get a meltdown. Use all 12 pegs and the kung fu grip to tighten the stock slipper and you should hold up long enough to get yourself the Strobe setup. :)
