What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.25.2009, 04:55 PM
Originally Posted by Thomas View Post
I haven't done any soldering to A123 cells. A German distributor is stating "direct soldering will damage the cells".
Not true. You do need to use a minimum 60W iron with a heavy tip on it to hold lots of heat because that allows for a very fast joint. The cells don't get hot using this method. If you try to use a plain tip iron, or a low wattage iron then you will have to hold it to the cell longer and it may overheat and be damaged.
