JThiessen
JThiessen's Avatar
07.06.2009, 01:22 PM
Fitting the 3906 tranny is relatively straight forward. You'll need to drill/cut a couple mounting holes, and dremmel out the hump a little to clear the CVD. If you do a revo conversion search, there were many of them well documented from a couple years ago.
Uregoner - not sure why yours nose dives - looks like you have the weight well towards the rear. Maybe you need to adjust what you are doing with the throttle when you go off the jump, or it could be your springs.
