07.13.2009, 01:23 AM
Originally Posted by J57ltr View Post
Wasn't really thinking direct drive I was thinking 4:1 to the motor. I have a bunch of prototype parts from when I was developing a small coonveyor for our company so I have a bunch of .080" pitch belts and some 60 tooth 1/4" sheaves and belts and 15 tooth sheaves that are bored to 5mm (our motor uses a 5mm shaft too). I think the gearboxes would have too much drag, and the only ones I have are about 30:1 and another that's about 100:1.
I swear that at the same RPM the lower KV motor had a higher voltage out.
This is going to be a pretty small unit about 16" tall and about 12" in diameter. Just for testing too see what I can do just with what I have laying around.
Jeff
Keep the ideas going!
I'm really curious about the small sheaves and belts you speak of. I've been toying with the idea of a belt drive rather than a traditional spur/pinion. Have any links or pics?
