my losi pinion wears alot too, not that much
but i have been kinda concerned. good know i can fix it
hey Mentat, just curious, but have the dogbone ends of your or anybody else's center drive shafts worn very much on the pins? especially the front one. i've only had mine for acouple month and if U look at the pin from the top, it looks like its nearly half gone. you can definitly see a gap between the outdrive cup and the pin. just curious if this is common aor what i should do to fix, grease maybe, idk. thanks
