07.18.2009, 03:49 PM
I agree. If you are gonna address one weak link, address them all or the effort is wasted. Generally, if a part (wire or connections) gets warm/hot then it is inadequate for the task. Of course, you have to take into account how the wire may be hot simply from heatsinking action.
Going larger gauge would be nice, but it gets tough because these vehicles are pretty small and large stuff gets clunky fast. Pretty soon, the wires/connectors are gonna be bigger than the ESC!
If high current losses on the wiring/connectors are a concern, going with a higher voltage setup using a lower kv motor is the way to go.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.18.2009, 04:17 PM
Oh for sure, that's why I am using 10awg wire now, for two reasons:
-Resistance of course to match the connectors...
-but it sucks heat away more heat from components, motor, esc (especially on a Quark)
I wouldn't have gone with 6.5mm plugs if I didn't switch to 10awg, and it does make a difference in temps, they are noticeably cooler than 12... as well, when you are WOT, there are large currents like you said, and 10 will feed the system that much more voltage.
My next upgrade would have to be a larger motor of course, as a 1512 would obviously have higher resistance than a larger unit such as a 1515, or a T8 truggy motor.
Whatever you can do to make a more reliable high powered setup, I'm all for it.
PBO
RC-Unobtainium
PBO's Avatar
07.18.2009, 07:38 PM
I've converted to bullets & use 2 x females on the battery, with staggered lengths (the lengths fit better & avoid most touch scenarios), all wires are now 10g - except for the small diameter I used on the additional 1000u cap I installed (didn't have enough room for direct esc attachment)
I'll post a photo later, it looks very tidy
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
