Whow, right after I typed that out, the voltage fell to 12.6volts.
I wonder if it just sits idle unless the reciever is also on, kinda like a sleep mode?
Jeff
No, I don't think it does... when I used AA alkalines, you turn the switch on, then after a 2 second pause, the LED on the back lights up and the voltage suddenly drops. It must draw a good amount of power.
