zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.21.2009, 11:58 PM
Yah, what ARE you doing?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.22.2009, 12:42 AM
Duhh, a quad-Neu powered 5th scale!
Ryu James
Ryu James's Avatar
07.22.2009, 03:11 AM
aqwut,
i see my lehner arrived safely...uh, your lehner i mean. glad to see it. those Neus are looking great! as long as the shaft length on each of them is 3/4" or longer then you will be fine. hell, my hacker motors have only 1/2" shaft. if they are shorter than 3/4" then call Neu (number on their site) and they will replace/fix.
you know how i bought that 2215 from offshoreelectrics for my 1/5 conversion, well the mounting holes on the front endbell werent even threaded. so i called Neu and they sent me a new endbell in like 2 days. they didnt even want me to send the motor in or anything. they just took my word for it and sent me new endbell, bearings, and screws and i just fixed it myself.
anyway, i can tell you one thing right now. if all you have driven so far is German motors and these are your first Neu motors you are in for a treat. you will never buy anything else from here on out. i am willing to bet that. i have tried all the other german brands now and although they are built well and are great motors they just dont have the same efficiency as a Neu or the same torque.
let us know what you think after you try them out. enjoy!
Jammin SCRT10 Neu 1512 1y
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.22.2009, 04:47 AM
I'm sure the motors will work flawlessly ...
Brian.. Yeah, I kinda figured that about the wires.. the lower KV motors have thinner wires... Also the one that didn't have the bushings had the thickest wires... so maybe, wires were too thick to use bushings... but I just triple shrink wrapped it to be safe..
ZPB... I was replacing all of the cheap motors with either a lehner or a neu.... If lehners were the same price as neu.. I would've bought them... :) but I'm always willing to try new things...
I have yet to try these babies out, Still waitin' for pinion gears .... Mike went away, and so did Dan Fischer... and SDP-SI doesn't work for me... so I'm kinda screwed...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
jzemaxx
07.22.2009, 06:21 PM
Dude, you know I have pushed the piss out of every NEU motor I have owned. I have ran them at RPMS WAY past their spec sheets say. They have been perfect and continue to kick butt in every application I use them in. They are hand built so you will have differences in tolerances...etc. Doesn't effect quality though....
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
aqwut
aqwut's Avatar
07.22.2009, 07:29 PM
Awesome... ! that's what I needed to hear.... Can't wait to try them out... JZE, did you have the 5mm or 8mm shaft..
07.22.2009, 08:51 PM
I also have tortued 2 of my Neu motors and one blew up on the second run and was replaced ( 18 months ago ) and since then...flawless.... and both are cool running as well. I have other motors as well...medusa, etc...and IMO they are worth the extra $ for piece of mind.
jzemaxx
07.22.2009, 09:13 PM
All mine are 5mm.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
07.22.2009, 09:32 PM
on a side note, jzemaxx...i have a neu question for you.
I've got an itch to drop a 1515 1.5D in my 8ight roller on 6S.
on 6S i run a max rpm around 55,000rpms with the neu 1Y...after about 10 top speed runs, i'm nearing 180 degrees geared 43/25. do you think i can realistically keep the same gearing with a 2700 motor?
I don't wanna waste my money if it's gonna be too much of a strain on the motor. what do you think?
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Ryu James
Ryu James's Avatar
07.23.2009, 12:57 AM
wow dude! that nuts. i would think the 1y on 6s is max. i know guys who have run the 1.5d on 5s but not on 6s. that puts it well over 60k rpm doesnt it?
jzemaxx
07.23.2009, 11:14 AM
I am working on building a 2.0 buggy myself with the same motor. I will be running 3S and 4S. Above that I think is to much rpms for extended run times. But that all depends on the length of your races. Mine are around 15-30mins.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
nitrostarter
nitrostarter's Avatar
07.23.2009, 12:20 PM
Thats actually only 59,940 rpm's unloaded, so less than that with a load.
My guess is with that gearing, you wont be able to make that many passes. Keep in mind also that Delta winds love to suck amps so I might push the ESC pretty hard.
On the other hand, keep the roller light and free rolling and I don't see a problem making a couple passes.
N. Rustler conversion
07.23.2009, 12:42 PM
Stum put a 1515 1.5d on 6s into an e-revo... With maxamps lipos.............
http://www.youtube.com/watch?v=85v85Pn3DMk
nitrostarter
07.23.2009, 12:44 PM
not sure his gearing was as tall as 25/43 tho...
DwightSchrute
07.23.2009, 11:05 PM
yeah, that's what i was thinking. and if it's got a huge amp draw it could be bad for the batteries too. maybe i'll just stick with the 1Y and start to build on my 18B for awhile. :)
