07.25.2009, 08:11 AM
You could always go to the new RX8 system by Tekin. What brand of li-pos are you using?
whitrzac
Can't catch this...
whitrzac's Avatar
07.25.2009, 10:37 AM
are you pluging the batts in the corect spots on the esc, or are they series and on of the plugs on the esc jumped??
the novak BEC does not like 4s on one side...
JThiessen
JThiessen's Avatar
07.25.2009, 11:44 AM
sounds like you didnt remove the red wire on the esc's radio plug
remove the wire and the lvc will work fine, and yes it is your batterys are the real problem
No, that's not supposed to be done on the the Novak - or, if it was, Novak omitted this step from the "single pack" wiring instructions.
That's the purpose of running the Rx pack.
Did you do the "turn the esc switch on, then back off" when you first turned it on?
Also, this should be in the Novak forum - NovakTwo will tell you to email customer service with a detailed account of what is happening.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.25.2009, 11:56 AM
Funny you mention that, In my older HV instructions it's there. In the HV Pro instuctions I didn't see it, I still did though because I felt it's still nessasary and it worked fine. Untill I bought a M.M.M. and sold the HV immediately after.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.25.2009, 02:17 PM
I'm guessing maxamps based on the clamed capacity, c rating, and sig.
I'm guessing either your BEC is damaged in some way or your lipos aren't providing enough juice. They could be damaged too or they're jusy crap...
