Losi Smart Diff and plastic spur compatibility
nl12
nl12's Avatar
Losi Smart Diff and plastic spur compatibility - 07.24.2009, 10:17 PM
Does the Losi Smart Diff and the losi plastic spur conversion work together?
GO-RIDE.com
07.25.2009, 12:45 AM
It should the SD works fine with the Kyosho plastic spur.
E-8ight - Tekin RX8 2000kv/4S
nl12
nl12's Avatar
07.25.2009, 08:49 AM
does the kyosho fit without dremeling? Is it a better choice than the Losi gear?
GO-RIDE.com
07.25.2009, 12:24 PM
It's a tight fit, but snaps into place as you tighten down the screws. From what I've read the Kyo spur is more durable than the Losi. If you do go with the Kyo spur then also pic up the Kyo outdrive o-rings.
