Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
1/8 buggy mamba max esc overheat ?
Jason
Unhappy 1/8 buggy mamba max esc overheat ? - 07.31.2009, 01:51 PM
I just got my 1/8 buggy today ( CEN MATRIX ) and the esc overheat badly .. I tried two different mamba max esc and two different motor still the same both motor is ok but esc can goes up to 200f in maybe 2min ... the bec was disabled ... punch control 50% ... motor timing lowest .. start power low ...
NEU 1509 2700KV MOTOR :
Differential Ratio: 2.888888888888889
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 13
Total Voltage: 14.8
Motor KV: 2700
Tire Diameter (inches): 4.3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0082
Spur/Pinion Ratio: 3.54 : 1
Total Ratio: 10.22222 : 1
Tire Circumference (inches): 13.51 inches (343.12 mm)
Total Motor Speed: 39960 RPM
Vehicle Speed: 50.01 mph (80.33 km/h)
Effective KV Value: 2700
KT constant: 0.5 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
FEIGAO 8XL MOTOR :
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 2084
Motor coil Ω: 0.0073
Total Motor Speed: 30843.2 RPM
Vehicle Speed: 38.6 mph (62 km/h)
Effective KV Value: 2084
KT constant: 0.65 oz-in/A
