JThiessen
JThiessen's Avatar
08.03.2009, 09:02 AM
My .02 - for a lot us we can digest that info and make decisions on gearing with some amount of informed intelligence. For quite a few users, its best to just give them one number, and let them run with it. Too many choices will end up with a hundred posts of "what gear ratio do I pick for my XXXXX". I dont htink anyone is saying the 1:1 thing is bad in any way, just that the results of the speed calculator have been good so far, so why change what isnt broken....standard human psychology.
simplechamp
simplechamp's Avatar
08.03.2009, 11:20 AM
It wouldn't be changing anything about the way the calculator works. The calculator already outputs tire circumference and final gear ratio. All I'm asking for it to do is take two numbers from the speed calc and divide them, nothing more. People who don't want to use it can pay it no attention, but it will be helpful to some people.
It's one extra number, based on numbers that are already being given in the speed calc. That's all I think it should be, not a whole re-tooling of the speed calc. It would just show you what your rollout ratio is along with all the other values the speed calc gives. How is that complicating things?
08.03.2009, 03:04 PM
its redundant. it doesn't necessarily complicate things but we are already utilizing a way of assuring safe setups. had we used "rollout" first that is what we would use, instead we just gear for a conservative speed. you're several years too late to show us a way of protecting our setups.
nothing against you or the rollout rule. if you want to use it, so be it. most of us just aim for our desired conservative top speed. BrianG is a frickin' genious and is uber helpful, he may add it anyway just to be thorough.
nobody's hatin', stick around, it's all about brushless here!
simplechamp
08.03.2009, 03:37 PM
I didn't think anyone was hating really. I just don't see the harm in adding it, it will help some people. You have a tendancy, at least in this case, to express your own opinions as those of the whole group. I understand if rollout ratio doesn't interest you, but give others a chance todecide for themselves.
I may be several years late to show you and other veteran members a way to protect your systems, but what about new members that join? They should have an opportunity to learn about using rollout ratio to properly gear their vehicle. It doesn't hurt to give people options to look at gearing a little differently, especially new members.
BrianG: Excellent! Thanks a lot
paralyzed just so you know I don't mean to be antagonistic, and do respect your desire to stick with what you are comfortable with. There will always be differences of opinion, no big deal.
