nitrostarter
nitrostarter's Avatar
08.05.2009, 01:07 PM
Premounts!
I second that notion! Pro-Line and AKA premounts are some of the finest available and their glue jobs are great and strong!
N. Rustler conversion
08.05.2009, 01:13 PM
I 3rd the "premount" notion.
JThiessen
JThiessen's Avatar
08.05.2009, 03:58 PM
Your referring to buying tires already mounted to the rims, correct??? Just making sure that I havent been missing out on some great technological innovation!!
We had a vendor come in a couple years ago and they claimed they were a year away from releasing a closed cell foam tire for the automotive industry, and they were looking at developing industrial casters with that same stuff. Lightweight and never goes flat. But I havent seen hide nor hair of them since. They even left me a small cross section of the tire - but I threw all of that out a while back. I'll have to dig around with some of my suppliers to see if they are still going down that road.
Brian - just glue the living snot out of them, run it through the dirt and get some good road rash on the sides of the tires. Then never clean them. Good to go!
08.05.2009, 04:57 PM
...Brian - just glue the living snot out of them, run it through the dirt and get some good road rash on the sides of the tires. Then never clean them. Good to go!
But I just got a new Viper body for my GTP (my absolute favorite car of all time - particularly the 90's models before they turned into Vette wannabes) and want the wheels to be pretty too. Seriously, the rear tires literally ripped apart the rear end of the stock body (Porsche) due to ballooning, and then when the tire ripped apart. I want to avoid that if possible because bodies this large are not cheap. As a matter of fact, my butt still hurts from what they charged from getting the Viper body. I mean, really; $45 for a press formed piece of this lexan??? That's just wrong any way you look at it!
What's_nitro: I did think of that. Basically, put in a few sheets of f-glass cloth and then enough f-glass resin to liberally coat the inside of the tire and spin in continuously until it cures. That should provide a nice 1/16"-1/8" thick coat of resin to stiffen the whole tire without adding as much weight as totally filling it.
I also thought about getting some plastidip (in a can, not the spray) and pouring it in there, but I don't think it will ever harden. I need something that needs to be mixed so it cures via chemical reaction rather than air-dry seeing as it will be contained inside the tire and airflow is minimal if any.
redshift
RC-Monster Square Tube
redshift's Avatar
08.05.2009, 05:33 PM
Even if you were able to distribute the resin or whatever evenly, you'd still have flimsy sidewalls. That would mean still running foams or using sprayfoam, both of which I think the point here is to avoid. Sprayfoam would probably require at least 4 holes inside the rim to get close to even, unless it was done first as mentioned. Still there is almost no way you'd be able to have both a balanced wheel and one that runs true... it seems to me. Balancing would be more difficult with either of the above ideas, I think, than it would be to do the old way. I've given quite a lot of thought to this and keep coming up empty.
Now if someone could make a sub-carcass type of molded piece that the tire glued onto completely (or almost completely) and then the tire & molded carcass assembly was glued onto the rim, maybe that would be something. Need something like thin lexan, but something that would not be attacked by the various glues.
And there would be many profiles for someone to have to mold for the various tire inners. The various shapes and sizes could be semi-universal I suppose but who is gonna invest in the idea......
Really shouldn't be this difficult
simplechamp
simplechamp's Avatar
08.05.2009, 09:06 PM
I thought maybe if you wanted to use a compound that required air drying you could use a small aquarium air pump and tubing. The pump would blow air through the tubing into one of the wheel vents and it would escape from the other vent. Constant flow of air to cure the plasty-dip.
However figuring out how to make this work while the tire is rotating? That's another story...
