03.28.2009, 02:52 PM
Cool, should make for a 'fun' setup for sure.
mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
03.29.2009, 12:36 AM
so far...
-took out radio box and reciever is in batt box
-drill bottom of MMM and chassis to route wires underneath
-painted: motor mount and plate, bulkhead retainers, and springs
-deanodized hex hubs
-rerouted servo wires into batt vents
-only visible wires are motor wires and batt wires
-switched motor to low cog position
plan to get
-rit dye
shock socks
5955tg
hd servo spring
aluminum servo arm
wheelie bar
aluminem wheelie wheels
tekno sway bar kit
pics will be up 2mrw
-mikey09120
mikey09120
mikey09120's Avatar
03.29.2009, 04:57 PM
-mikey09120
mikey09120
mikey09120's Avatar
03.29.2009, 04:59 PM
-mikey09120
03.29.2009, 11:15 PM
Looks very nice- I like the RX mounting spot, makes for a clean layout. Only thing I'd be concerned about would be a bad front end collision. Could damage lipo, RX or both...
mikey09120
mikey09120's Avatar
03.30.2009, 12:17 AM
i have the battery stop holding it towards the back and is also servo taped there as well. leaves me with 150mm of space left... perfect for flightmaxes
-mikey09120
03.30.2009, 06:46 AM
Clean.
mikey09120
mikey09120's Avatar
08.08.2009, 07:55 PM
some updates. i have died the rockers and chassis black. it looks sick!
i also have a bit of a story to tell. i attempted (make special note of ATTEMPTED) to dye the transmitter case. i died the back half of my traxxas 2.4ghz radio case and it turned out good. so i put the front half into the dye and i begin to assemble my e-revo. so i come back in half an hour to check on it and alot of the water evaporated out of the pot leaving some of the case sticking out of the water and the part of the case that was not submerged ended up melting and was badly distorted
i learned my lesson. dont dye without checking on it. haha. i had to learn it the hard way
i also reciever my zippy 3s 5000mah 30C lipos along with my charger and power supply
now i just have to solder the connectors
and some of you may know that my MMM was sent in for a reciever lead replacement. so im also waiting for that. pictures will be up soon
if anybofy has a traxxas transmitter case that they are willing to sell or give. PM me
-mikey09120
08.08.2009, 08:32 PM
Talk about your Blacked Out ERevo
On the tx casing issue (), I could be wrong but the stock AM txs look identical pretty much, so it might be possible to pick up a cheapy one from ebay and swap out the melted half, unless ofcourse you've already replaced it.
mikey09120
mikey09120's Avatar
08.08.2009, 09:31 PM
yah. im going all black! ninja e-revo haha
i havent found a replacment yet. i cant belive traxxas doesnt sell just the case.... i guess ill heat ebay and see what they have. thanks for the info and support
it means alot coming from suicideneil
-mikey09120
BlackedOutREVO
08.08.2009, 09:41 PM
Haha, im everyone idol. I started a good trend lmao
Wheres the pics?
mikey09120
mikey09120's Avatar
08.08.2009, 10:36 PM
camera battery charger is nowhere to be found
-mikey09120
update
mikey09120
mikey09120's Avatar
update - 01.23.2010, 04:03 PM
soldering pads still on board after ripped out
hole drilled through battery compartment for ESC wires
wiring
wiring under chassis
broken front body mount. plastic welded back together but wasnt enough and it broke again
landed on wing when i jumped and broke wing mount
zippy 3s 5000mah 30c lipos. awaiting traxxas connectors to be soldered on and re-shrink wrapped
dyed the transmiiter case
-mikey09120
mikey09120
mikey09120's Avatar
FAIL!!! anybody have an old traxxas tramitter case they dont need?
hubs deandonized
BEAST
how she sits now
proof that God does exist
just a little update
To Do:
-ship MMM to castle for new receiver wires
-solder traxxas connectors to batteries and charger
-buy new front and rear body mounts
-get a new transmitter case
-mikey09120
01.24.2010, 05:30 PM
I was looking at that 1st tx picture, thinking that looks alright... then.... oops. I would wager that an am radio case would be compatible, though if it isnt it wont be much $ wasted- must be a million of those on ebay at the moment I would have thought?
