Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
08.13.2009, 11:57 AM
In case no one has noticed, I made several changes the last few days. The following list is taken from the release notes file:
- Added form import feature. This allows the user to save prior setups into a file and reload them at a later date.
- Changed the method used to export field values for forum posting to prepare for a possible new feature.
- Added more detailed "help" explanation for motor current value in the top speed estimator page. Also, added a warning when the motor current value exceeds 250A.
- Added more details for lipo Y adaptors to help reduce the chance of mis-wiring.
- Added e-Savage metal tranny ratios, and spur gears.
- Added HPI Baja, HPI Dirt Bonz, Trx Response, and Trx SportTraxx tires.
- Added Great Planes Ammo 36-56-2600, 36-56-1800, 36-56-1200, 36-88-1280 motors.
- Added Imax B5, Imax B6, Imax B6AC, Imax B8, E-Station BC8DP chargers.
I probably need to explain the new import feature a little more. There is a new button on the "top speed estimator" and "parameter solver" pages that says "Import Values". This lets you import values from previously exported data. You would save the exported data to a file (or post into a thread), and then at a later time/date, copy the text to your clipboard, and then re-import the data using this button. The form fields will be repopulated with the data so you don't have to manually type in all the data again.
