Rivermaxx
08.13.2009, 04:00 PM
Hey Neil thanks for coming in on this one your knowledge will be greatly appreciated. I have extra thinner 2mm titanium skids I will be using, quite a bit lighter then the 3mm thicker ones. Proline slipsteam even sounds fast, I will check it out. 25 teeth aye let me go check the calc for speed with that gearing. edit I just ran the calculator with the 51 tooth spur through a g1 tranny and 4.5 inch tire its not fast enough.Wheres the monster center diff when I need it The tires are killing me because the biggest good rim I can get is the new vtr wheels with a .300 thick peice of foam rubber wraped around it. The foam shouldnt be any bigger because of centrifical force exerted on it. At least that what I was told. How about buggy wheels with foams with a direct drive setup. I need a motor that the shaft come out on both sides. Not to mention a lower gear in the diffs. With the calc I get speeds to ~145 mph with that set up .
You guys think I could run 1 motor in the front on 6s and one in the back on 6s direct drive? I can buy another complete mmm set up for less than it would cost to buy a special neu motor.
