Soldermaster Extraordinaire
02.27.2009, 01:34 AM
Wow. It's been a while. Oh wait- we're in a recession and I have no liquid assets! That's why!
Anyhow, I ordered up some 12"x24"x0.08" (2mm) 7075-T6 aluminum plate a couple weeks ago. The other day I got around to cutting it up. Here's what it looks like now:
I also ordered a 12"x48"x0.025" piece of polycarbonate to make the sides and the internal support structures. It came today, so hopefully next week I will have time to cut it up a bit. I'm going for the "speed wedge" look, with a twist- I'm going to design a venturi into the top so that it will create a vacuum inside the body and (hopefully) help stick the car to the road.
02.27.2009, 02:06 AM
Hmm, sounds like the pike's peak racers that have the huge tunnels that produce downforce...
I found that Lola style bodies work like a charm at speed. Problem is none are made that are wide enough to work on a gtp...
02.27.2009, 02:11 AM
I like those Lola's too, for 1/10 TCs. IF they made one for 1/8 cars, it would be too high in the back for real speed runs. Too much rear downforce. That's flip territory. I suppose you could chop down the rear wedge a bit. Maybe replace it with a normal wing.
03.05.2009, 02:39 AM
I finished outlining the body's profile on the polycarbonate. I am going to buy a thinner blade for my band saw before I even attempt to cut it out (1/2" blade on there now for cutting Al). I think a jig saw would make a really rough cut, and I don't want to crack/chip the edges either.
Here are a couple pictures of my design. The "notch" is at the front of the car. It's where the venturi will draw air in from underneath the car.
Now for the million-dollar question: Should I put a wing on the back???  It would be made from the same polycarbonate/aluminum as the body.
03.05.2009, 03:51 AM
looks cool, how much will the body weigh?
Originally Posted by Semi Pro
03.05.2009, 11:17 PM
I don't know for sure. Maybe 1-1.5 lbs.?
08.21.2009, 03:00 AM
Sooo... I'm poor as s#!7 right now and as such I haven't been doing much on any of my projects. I did finally buy some parts for this car- An RC-M 8T motor mount, and the OEM 8T CD mount/brace kit. These will allow me (hopefully) to drop in the Slipperential I bought 5 months ago. I need a short dogbone for the front ( these?) since it will be FWD and I want to move everything forward. Oh and I've cut out the polycarbonate body panels. I'll get pics up later today.
08.21.2009, 01:31 PM
Awesome, 'bout time for an update on this beast!
08.22.2009, 07:30 PM
Ok, I forgot to take pictures before I tore it down....  Oh- and I read that the Slipperential was a drop-in for the 8ight so that's why I bought the diff mounts. Guess what? Mine isn't! It came with 8x16x5 bearings. I need some 8x14x4 flanged bearings. ..... Mike's 8ight motor mount is frakking sweet though. I like how you can remove the motor- with the screws still in it!
So I'll get the bearings and take some pics when it's all back together.
Fat Kid Engineering
08.22.2009, 08:16 PM
Where'd all the pics go ? I've read the whole thread and it's pictureless -1 of your build ?
Sounds like a great prodject and would like to "see" more.
08.22.2009, 08:20 PM
Fat Kid Engineering
08.22.2009, 08:34 PM
You have definitely put a LOT of time,thought,theory,$$ into this speed demon.
I sincerely hope to see it work out well for you,so many variables I struggle to keep up.
I look forward to seeing more now that I'm subscribed to the thread.
Good luck.
08.22.2009, 08:49 PM
Thanks Bondo!
Fat Kid Engineering
08.22.2009, 09:01 PM
Fly Straight and True Like a Warriors Arrow of Death, My Young Speedy Samuri......
10.14.2009, 08:39 PM
So... long time no update I guess?
The speed project is postponed until the spring- it's getting chilly here now and rubber loses traction fast in the cold. I purchased a new battery tray, 164x55mm so the FP pack can lay down. It should help the CG quite a bit. Trying to decide whether to stick with the 1515-1y and MMM, or break out that LT-6s150 that I never got around to running (sorry Lutach), OR buy the Tekin RX8 2250 truggy combo. I'm actually leaning toward the Tekin 'cause I like the sensored startup soo much. The MMM has the BEST sensorless startup, but if you run very tall gearing (ie. speed runs) it still suffers a lot.
Hopefully the recent spike in the market will make people come spend their money so that I can have money to spend!
