What will break next on my Maxx?
Chris911
What will break next on my Maxx? - 01.17.2006, 11:52 AM
I'm using HV-Maxx on 14 cells
Have already upgraded
all 4 drive shafts to MIP's
center drive shafts to MIP
Steel idler gears from UE
Will be intalling Gorilla Maxx single speed transmission soon. I think that will leave one plastic gear left in the trans? I would like to replace it any suggestions?
What should i upgrade next the diffs?
CCristo
01.17.2006, 12:46 PM
No one makes a metal output gear other than OTB that I know of.
The diffs are the next to go. UE diffs will handle anything you can throw at them, but if you are on a budget the maximizer cups will get you by. FLM offers 1/8th scale diffs for the maxx, but I've never seen them up close. Maybe some one here can comment on them
squeeforever
squeeforever's Avatar
01.17.2006, 02:00 PM
i know serum, coolhandcountry, and mmdooley have them and love em. thats what i would suggest with the 6 spyder ue diffs or the 8 spyder if you can swing em.
Chris911
01.17.2006, 02:05 PM
So you guys think the stock diffs wont hold up to a HV on 14 cells?
If i use the UE 8 Spyder diffs what spur and pinion gears will i need? Right now i'm using 70 spur and 14 pinion and i'm happy with the power and speed it gives me.
Nick
COOKIES!
Nick's Avatar
01.17.2006, 02:29 PM
I use Maximizer and it's more than plenty for diffs'.
The stock diffs are enough to take the HV on 14 cells anyway. I would consider the Gorillamaxx chassis instead.
~ Nick.
Chris911
01.17.2006, 02:39 PM
I never liked the look of the Gorillamaxx chassis i don't like how you can see the batteries below the truck body.
maxxdude1234
maxxdude1234's Avatar
01.17.2006, 03:23 PM
you can always lower the body. I run a chassis similar to the G-Maxx chassis, and I've got some low profile shock towers so the body sits a bit lower and covers up the batts
