brushlessboy16
brushlessboy16's Avatar
08.25.2009, 11:17 PM
they are one millimeter wider then the 4000packs, the 3s 4k pack is a snug fit in my slash.. it just might be possible... might need some light dremel sanding though.
You will need a notch for the wires to come out through.
maxair45
maxair45's Avatar
08.26.2009, 12:21 PM
Dang that doesn't look safe. Wheres the shrink on the motor wires?
Don't run it until you dremel the notch in the side. It'll pinch the wires and most likely destroy the battery(check the biggest blunders thread for the full story).
brushlessboy16
08.26.2009, 04:54 PM
clear heatshrink from radio shack. works just the same
