Gustav
Gustav's Avatar
01.17.2006, 09:27 PM
Originally posted by coolhandcountry
I tried to run the esc touch the motor on bench. It worked perfect. I mounted it back on truck with some stuff a little different. I don't know results yet. Seems to be better but not 100%. Could I have my motor to low on chassis. How could I shield my motor with something? I was wondering if maybe the motor builds up electricla field and transfered to the chassis cause it is so close to it. Any opinions on this.
That's funny,that's excactly what i was thinking but didn't know if it was possible.The motor is extremely close to the chassis and it is one BIG magnet.
Also would make sense that when you tried a different motor,it was improved and not quite so close to the chassis? I'd try shielding with foil to start with between the motor and chassis.Frankly i couldn't tell you if there is a scientific basis but anything is worth a try at this point.
Strange that it works with the schulze though,makes me think it's noise from the BKs causing the problem,have you tried the esc further from the chassis?(on the shock tower for example)
