Krawlin
Got brushless?
Krawlin's Avatar
08.30.2009, 08:40 PM
I'm 90% sure they'll fit, hopefully someone else will chime in on that.
People have had problems with helical cut gears. My 2 cents is that it is difficult to get to the diffs if you do have a failure, so go with the best right away and hopefully avoid a teardown.
Also- figure out your whole setup and put it through the speed calculator. I would have been way better off with a truggy diff ratio in my FLM combos, but I put in UE super 8's and I need tiny pinions now.
Thanks Herald!
I have also been considering getting Hot Bodies diffs as well.
And I already put it through the speed calculator. With my current setup (center diff and stock maxx diffs) I need a 9 tooth pinion and 51 tooth spur to have it geared for around 44MPH with some tire ballooning, with Mugen truggy diffs, I will be able to run a 15 tooth pinion and have roughly the same speed/torque.
Monster GT Conversion
