brushlessboy16
brushlessboy16's Avatar
09.02.2009, 11:37 PM
My pack (4s 500mah) took a little over 2500mah after an 11 minute run. seems about right.
ryan, did you get my last email?
Ryu James
Ryu James's Avatar
09.03.2009, 02:24 AM
yeah got your email. just sent reply. started on reply yesterday and got interrupted.
Jammin SCRT10 Neu 1512 1y
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.03.2009, 01:08 PM
That's a beauty track, I would love to be on that surface for a day!
James, I think he says "just a tad faster than the ICE buggies..." ICE = internal combustion engine.
Aqwut, NO, nahuh! lol I am not sure whether they just suck or I am that much better, but I do know that on practise sessions I was passing lot's of buggies and truggies and they couldn't keep up. I had the suspension very low, P-3 rockers in rear, the rear skid was almost dragging when on power, crimefighter LPR's, handled wicked anyways. Should gain an even gibber lead once I lower the CoG of it, check my thread on it...
zeropointbug
Z-Pinch racer
09.03.2009, 01:11 PM
Oh, and James, which model Hyperion charger do you have?
If you have one of the fairly newer units, then all you do is push mode ONCE after the charge has ended, that will bring you to the other screen that tells you mah put into the pack.
kalbien
09.04.2009, 07:47 AM
if you have one oof the older ones you push that button that you change battery type before charging....
