Rc8te - CC 2200kv motor installation issue
The Dane
Rc8te - CC 2200kv motor installation issue - 09.03.2009, 05:51 AM
Hey Guys,
Just finished building my Rc8Te and had a problem with mounting the castle creation motor in the motor mount. The diameter of the motor seems to be a bit too large , as it scrapes against the chasis.
In order to get it fit , I had to remove the center differential with the motor mount attached and then install the motor in the mount.!!
Once the motor was mounted I could reinstall the center diff.
This gives me limited option of quickly changing the pinion as I cannot move the motor without loosening the center diff brackets.
Have any of you experienced the same. ???
Have a great day.
