danhfvcsd
09.06.2009, 06:14 PM
If you are planning on using that clutch, your gonna need mechanical brakes.
y'know what? I didnt actually even think about that! -lol- Thanks for pointing that out mate, i'm glad i havent mounted the motor up yet, that's good tho, as i can change plans to suit the pinions i already have from you Mike =)
Also, what are the back side of the batt packs resting against? I don't see anything there? :)
There's the rear pivot blocks? -lol- I have been thinking about that, and was gonna mount a strip of alum using the one screw and countersunk screws so it is flush instead of those button heads - if i use a thin strip, it'll give a lil more support up higher on the packs, rather than just the 8mm or so of pivot block there =) I'll get some pics tonight and it'll look better than it sounds -lol-
Hey, so i assume the slipperential is a direct drop in then, right? Do you recommend the 50t or 46t?? =)
