brushlessboy16
brushlessboy16's Avatar
09.12.2009, 11:49 AM
Hmm, cold solder joint? Check your motor and make sure the wires leading into it arent stripped and shorting on the can.
drkdgglr
09.12.2009, 12:32 PM
Ok, just checked the motor wires and they're fine. Could a cold solder joint on the 5s lipo cause this? It's the only new part in a setup that I've used before with no problems.
riverat1540
riverat1540's Avatar
09.12.2009, 02:36 PM
my guess is the high amp spike as well. my muggy just blew a mmm3 on 6s running the 2200kv neu 1515/1y tying to pull wheelies at high speed. that draws alot of amps with the heavy losi's when u push them hard under alot of voltage. but with your gearing im not sure, i was geared for about 50 when i had my problem on 6s. motor and battery temps were also fine when it flames up.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
lutach
lutach's Avatar
09.12.2009, 04:06 PM
Georges told me for the car ESC he was going to make some changes specially with the PCB. I did some tests with the 6S 120A and had to add a bigger heat sink and a fan.
