Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
kostaktinos_mt
09.15.2009, 09:56 AM
Originally Posted by aqwut View Post
I just hope the diffs hold up long enough for the tires to even have a chance to balloon.. I have a whole bunch of gears that came with it as well... I think the differential is 3:1, the Center Diff is 3:1.. Pinion is 25, Spur is 36.. and transfer from 24T to 25T on the center diff... I'm not sure how to figure that out.. I'm guessing my FDR is around 12.44... Some one please correct me, or help me figure out the FDR.. I'm going to try BrianGs Speedy thing...
looks like around 13.5 to me...
i would drop to a minimum fdr of 18:1, and also lower the motor voltage to limit rpms...
60mph for a truck this large will only create broken parts imo...
  Send a message via MSN to kostaktinos_mt
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.15.2009, 12:19 PM
I think you are correct, but I have to make a good video right?...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
KaztheMinotaur
KaztheMinotaur's Avatar
09.15.2009, 12:29 PM
How are you connecting the cut off clutchbell stem to the motor shaft.
I haven't worked on mine for a while either...been working a lot of OT lately...always nice to get a pay check that is $600 bigger than normal.
aqwut
aqwut's Avatar
09.15.2009, 04:50 PM
I know what you mean about OT.. I work 55 hours every week.. straight pay... but that's extra RC money ... I'm connecting the cut off clutchbell shaft to the Brushless motor shaft with a Coupler... I want everything to look stock as possible, that way I have lots of play with the Gearing...
Coupler dimensions..
18mm wide x 22mm long
End A: 9.05mm wide x 8.0mm deep
End B: 10.05mm wide x 14mm deep
Each shaft will be held together by 2 set screws, 90 Degrees from each other... so 4 set screws total.. it will hold up without any problems.. I probably only need 1 set screw.. but rather be safe than sorry... Once it get's here I might have to shorten the coupler so it will fit in between the bearings...
Sample Video
aqwut
aqwut's Avatar
Sample Video - 09.16.2009, 11:35 PM
Finished the rear mounts for the motor...
All that's left to be done is figuring a way to mount the batteries, get new steering servo and cutting excess aluminum from the front mounts..
And this is the Coupler thingy...
Little sample video..
http://www.youtube.com/watch?v=tgTojk0XfF8
