zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.15.2009, 06:13 PM
Hmmm, depends how much confidence you have in yourself really... if you are good enough, you could make anything out of CF almost, and make it look good as well. But the more complex the shape, the less appealing it will appear just because of limitations on getting the surface epoxy just right.
I think there is a reason why not very many people have attempted a CF chassis, mainly because of getting the piece bent, namely the kick-up angle. I would think it would weaken the epoxy, and thus the 'composite' strength by the heating and bending.
I wonder if a Teflon mold would work for getting the angle of kickup right if laying your own CF fabric?
whitrzac
Can't catch this...
whitrzac's Avatar
09.15.2009, 06:49 PM
only one way to find out... thank goodness that ebay CF is "cheap"
rchippie
rchippie's Avatar
09.15.2009, 07:16 PM
why could'nt you use the originale chassis as a mold if your going to lay your own CF ?. Just put masking tape on the chassis as a mold release .
REAL MEN RUN BRUSHLESS
whitrzac
Can't catch this...
whitrzac's Avatar
09.15.2009, 07:55 PM
I could... but then I have to make my own CF
rchippie
rchippie's Avatar
09.15.2009, 08:21 PM
Maybe you can call a couple of the CF dealers & see if they can mold you a CF chassis of your aluminum chassis .
pb4ugo
09.15.2009, 08:58 PM
You could, but the bend radius would be just a bit off (either larger or smaller depending on whether you used the top or bottom). Plus you want to make your blank bigger than the final piece and cut to final dimensions--that would be difficult to do that way. It's fairly easy to make one out of wood. Assuming you're using MDF, with some lacquering and a mold-release coat the finish would be good enough in the CF (though not as good as these glossy ones--you'd need highly polished aluminum or glass for that), and it would be strong enough to hold up to the vacuum if you decide to try that out.
whitrzac
Can't catch this...
whitrzac's Avatar
09.15.2009, 09:16 PM
now there's an idea....
whats wrong with useing a heat gun?? its only the front kickup....
zeropointbug
Z-Pinch racer
09.15.2009, 11:35 PM
yeah, but that front kick-up plays a big roll in the handling of the vehicle, you get it wrong, and it handles like bettie crocker on roller blades.
whitrzac
Can't catch this...
whitrzac's Avatar
09.16.2009, 12:50 PM
so I'll bend a pice of sheet metal to the exact angle....
