zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.16.2009, 01:14 AM
So running a lower kv motor (with a higher kt) on higher voltage results in a torqueier power system.
I wouldn't say that, a lower kv. motor will draw less current to do the same thing (torque), a higher kv. motor WILL draw more current to do the same thing as well. They will both be equally powerful and same torque levels for a given max rpm setup.(well, the higher voltage will be SLIGHTLY more powerful ) The only difference really is running temps, they will always be lower when you increase voltage and lower the kv. value.
