Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
09.16.2009, 06:41 PM
I wouldnt butcher the Ti skids too much, those things are so hard to get hold off & you'll regret it later down the line.
Velco pads is fine, use rear body posts in the front too as they have that cross brace; cut the actual stubs off then use velcro strips to stick the body shell to the cross braces- shouldnt be an issue with the paint coming off the body, not if you use an adhesion promoter and the proper flexible lexan plate.
The front skid itself could be an issue, seeing as it is angled in such a way as to direct air under the truck, therefore creating lift- needs a front wing I reckon, mounted off of the front bulks perhaps...
Too much fun to be had working all these things out, but thats half the fun....
