Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.18.2009, 02:51 PM
Originally Posted by Cain View Post
Reason he can't gear down is that there is limited gearing room on the Hyper 9E with the Neu and Tekin sized motors. I would say that the Tekin 1900Kv motor would be a good choice or if you want a Neu motor you could look into the Neu 1512 2050Kv motor, if you are looking into the later drop me a as I have one I am not using recently serviced. You trim the lower fin and you probably can gear to a 13T pinion I am thinking.
Or, you could do a 3S setup with your current motor. That should work really well too and I have heard of others doing it.
I appreciate that Cain, I may consider that. But with my thinking If I go to the lower KV 1700-1800KV I can run a bigger pinion and have the top end I need with out cramming the motor so tight to the center diff assembly ?
I dont Know, I get what I think is a good idea and confuse myself by thinking to much ?
I want to stay away from the 3s, I have one only and don't wish to purchase any more. I just dropped another 400.00 on several HC 4s packs.
