Mm I would buy one if they had stock.And they can't tell me when that will be.So need to make one till the stock comes in.Or import a few..
I will see what I can do tomorrow.Have a few clutch bells here I can butcher..lol
Mike has them in stock i belive, or you can Try seeing if one of our europen members has one they can send you . If your going to use a CB. Make sure you use a hardenend one or your just wasting your time . Ther way ben is describing is the way they were made . But griffin used STAINLESS stell instead of aluminum . Just make the hub bug enough so you get good bite from the set screw .
