wallot
wallot's Avatar
09.23.2009, 11:44 AM
to get as many people attarcted to this class we do not have any rules as far motor/battery goes.
some people like higher voltage so let them run it.
I found interesting rule as far battery goes - some US club has Watt/h limitation.
So poeple running 4S can use 5000mah batteries, 5S 4200mah batteries and 6S 3300mah batteries to get about same runtime which is important if you have longer mains that need battery changes.
However i dont think battery changes are way to go as it would lead to unsage battery mounts just to be able to change them fast.
We run using standard electric system with 3mains with 2 best counting.
If you are security concerned than you have to limit batteries to 4S so you can run hardcase lipo. Higher voltage hard case lipos are still very rare.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
