mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
06.06.2009, 10:17 PM
Anyone know something about the Team Losi Mini LST2? I am wondering if the upgrade diffs by Team Losi for the Mini LST2 would fit inside the ERevo's diff cases. I counted 38 teeth on the ring gear, not sure how many on the pinion. Either 13 or 14 teeth on the pinion would be my guess. I don't know what the size of the output shafts are, 4, 5, 6 mm?
No brain, no headaches.
Thumbs down 06.06.2009, 10:24 PM
Thee mini lst diffs are small enough to fit inside of a revo diff cup. And they are not strong at all.
mistercrash
Guelph, Canada, eh!
06.06.2009, 10:33 PM
Not strong eh! Well scratch that idea. Thanks Linc.
Gee
A Horse's Ass
Gee's Avatar
09.20.2009, 07:34 PM
Will the Losi Aftershock differential work for this mod? Is it the same diff that in the LST2 or not as good?
Semi Pro
Semi Pro's Avatar
09.21.2009, 03:13 AM
its the same diff
a muggy diff is better suited because of the higher ratio but the aftershock will work just as well
xxl - lst -lst2 - aftershock all have the same ratio (xxl has a heavy duty diff cup)
muggy has its on ratio
hope that helped
Gee
A Horse's Ass
Gee's Avatar
09.25.2009, 01:50 AM
Thanks Semi that helps out. Why would the muggy diffs be better? When I plug the number in to the speed calc it drops the overall speed down by 20mph. Would it be more efficient?
When I get a bigger spur on here I can use a smaller pinion. Right now the 25 is the only one that will mesh. These #'s are with the stock diff.
Stock E Maxx Diff
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.7222222222222223
Additional Ratio: 1
Spur Tooth Count: 58
Pinion Tooth Count: 25
Battery Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 5.8
Top Speed (MPH): 74.1061 MPH
With the LST Differential
Differential Ratio: 3.3076923076923075
Additional Ratio: 1
Motor KV: 2200
Top Speed (MPH): 63.7657 MPH
Muggy Differential
Differential Ratio: 4.090909090909091
Additional Ratio: 1
Motor KV: 2200
Top Speed (MPH): 51.5576 MPH
I do have a couple more questions out of curiostiy and just the need for more knowledge. I found Mister Crashes Photobucket and looked over his pictures which asnwer many of my questions but I didn't see any of the insides of the LST case that hold the differential. Thanks for keeping your photo public MC.
I have been working on getting a set of these but there hasn't been many listed on ebay and if you don't win the auctions there's like a 5 day wait till the next one is up. A listing just came up with a buy it now price so before I spend that money I wanted ot see what the options were for installing a custom differential inside of the LST case. Well those didn't last long already sold.
If the LST case that goes around the differential can fit a Half case sized 1/8th scale differential and standard ring gear. I may only need to pick up the LST cases.
I am curious about the the internals to the LST differential or actually the differential itself. Is it a normal 1/8th differential or is it like the half size with the narrow gears planetary/sun gears installed inside?
The ring gear that is used for the lst the "Losi Viscous Differential Ring Gear" looks different then some of the ring gears I've seen. Looks similar to the traxxas ring gears. Can other ring gears be used in this differential or does the case the differential sits into prohibit that? It looks like the same size and hole patter as other ring gears. Is it the same diameter as other 1/8th scale ring gears?
For my last one in this post.. Why is this thread in the General Discussion forum when I am always thinking it is in the revo forum. Maybe a mod could move it unless someone thinks it is better off in the general forum......
09.25.2009, 02:57 PM
Ok Gee,
Here goes... The internal of a lst diff are pretty much the same over the losi line, including sportwerks. eight buggy and truggy 1.0 diffs will fit the lst cases. Plenty of options on those diffs on wbay, and just buy the lst cases. Al cases are the best, plastic cases will crack the noses with very hard use/big tires.
All of the internal gears are the same, as are the cross shafts, and most use 8x16 bearings. Some of the 8b and 8t use 8x14 bearings.
I have a wealth of knowledge on these...ask away!
just_now
just_now's Avatar
09.25.2009, 10:25 PM
You guys are a big help to me. I am building a Revo myself with LST diffs and this is great. Thanks.
Gee
A Horse's Ass
Gee's Avatar
09.27.2009, 04:16 AM
Well that sounds good. You can use a different ring gear/pinion in the LST cases as long as they are the standard 1/8th scale size. Selective gearing vs just using what the LST comes with. Although it doesn't look there a bunch of different option out there.
Semi Pro I did some more calculation or should I say played around some more with Brians Calculator. I found that the muggy gear ratio bring the numbers I was putting in real close to the 1:1 Rollout. So I think I am getting what you mean by the muggy diffs being a better fit.
Thanks for the help guys.
redshift
RC-Monster Square Tube
redshift's Avatar
10.01.2009, 07:11 PM
Only semi-related, but I sent you a PM linc.
10.01.2009, 08:28 PM
I will check my mail...
Semi Pro
Semi Pro's Avatar
10.02.2009, 05:15 PM
no problem, i didnt realize you had posted more questions, but im glad you figured it out on your own
the 8ight diffs are a bad choise to try and put in the lst cases, the rears will not work at all due to the inverted ring gear and the pinion shaft is much smaller so you would need a very odd bearing to make up the diffrence
bigsteel
10.05.2009, 04:51 PM
hey guys,new member here and i just scored some aluminum cased LST 2 diffs off ebay,i've read over this post a few times but im still kinda lost,is there a list of ALL the parts id need to do this? i've got THS CVD's on all 4 corners,will they still fit? and what center drives do i use? will stockers fit?.thanks.--josh
10.05.2009, 08:09 PM
Your cvds should still fit, unless the cups on the lst2 diffs are incredible shallow or tight.
As for centers, you have 2 options:
1. A Hotbodies or similar drive cup with an 8mm bore, coupled with custom length center dog bones- Mike (our Lord and master of RC-M) can make those or hit up RCAlloys.
2. Buy a couple of these to go on the 8mm diff output shafts, then you can use your stock plastic center drive shafts.
I wouldnt like to say for definate, but it is possible that if you had center cvds or dogbones already, they may still fit fine if they are a little on the loose side; this is because the 8mm output shaft on the diffs is slightly longer than the normal 5/6mm shaft on the stock diffs. On my Gmaxx for example, I just had to grind the tips of the dogbones a tiny bit & they worked fine with my UE diffs that also have an 8mm output shaft. I would also look through this thread again for references to what people are using for outdrives and center shafts, just incase you overlooked it.
Welcome to RC-Monster, The Encyclopedia Brushless
EDIT: Just looked through myself, and from post # 37 onwards is alot of info on driveshafts- I forgot you have another option for the outdrive cups. Open up the diffs, remove the cups from each side, and replace with 4 of these, 2 in each diff. This will allow you to use the stock cvd drive cups on the diffs, to avoid any possible fitment issues. Beyond that, you just have to worry about making the diffs fit the bulks...
bigsteel
10.06.2009, 08:07 AM
thanks alot!--josh
