rc4x4nut
03.13.2005, 01:00 PM
I am not sure of the 1/8 scale shocks but I am using the powerstrokes (excellent shocks). However, the over sized shock bodies limits the mounting positions on the shock tower because I am running GA bulk heads. The most inward you can set is the middle position. Its not a biggie though. With the shocks in the middle of the shock tower and the lower set to the furthest setting the A arms are nearly parallel to the ground.
