Outrunners supported/held by the shaft?
sikeston34m
10.04.2009, 04:42 PM
At the front of the motor on the mounting side, there is usually a locking collar or a snap ring. After removing that, just pull off the endbell.
Be careful. The magnets are very strong and if you slip, it will pinch your finger tips.
I hope this helps.
When you get it apart, check out the winding on that bad boy.
sikeston34m
Find all posts by sikeston34m
