bluefisherking
10.07.2009, 12:53 PM
Originally Posted by Snipin_Willy View Post
Shim up the center diff to give you the motor space you need.
I don't quite understand. It is the motor diameter that is the problem, not the length... Oh, or do you mean just raise the whole centre frame, diff included? I guess that could do it, although I wonder if 2mm shim would be a little less stable than stock.
