10.07.2009, 05:08 PM
Well, the MMPro is very close in size to a MM, if that tells you anything. Most of the height is due to the fan assembly, and if being used in something that small, heat shouldn't be an issue even without the fan. I guess it depends on how soon you plan on getting the ESC; I would imagine the MMPro will be out sooner than the ICE ESC.
