Byte
11.15.2009, 06:09 AM
Originally Posted by wallot View Post
EOS 1210i supports 2C charge. Been using it for couple years now however I plan to get the new ones with up to 5C charge :)
Do you know if it is possible to trick this charger, like BrianG said? So it will charge at 2C+?
TCS is a feature that lets you select a %'age to charge to. Say you're not going to use lipo immediately after running, TCS lest you tell charger 80% (or whatever) and it then charges lipo to 80%.
Its the equiv of 'store' mode in other chargers.
Ok, thank you very much!
But now my question is still about the power supply... Which one should I buy?
