11.19.2009, 05:28 PM
If you want to waterproof you lipos it is pretty easy. Get some plastidip in a can, ziptie the wires together, and put some clear silicone aound them (make sure it gets squished between the wires) Let the silicone dry, then dip the lipo in the plastidip. Put a couple of coats on and you will be good to go. If you leave the shrink on you can always cut it off and remove it and the plastidip.
