Lauri
12.04.2009, 01:40 PM
Limiting droop is a tricky thing for offroad because usually you wanto to run maximum arm movement. But it might work for you - it limits the weight transfer also.
Be sure to check out the Xray offroad setup book. You'll find how to limit the weight transfer also from there. http://www.teamxray.com/teamxray/pro...p?prod_id=3346 (third from top)
