Unsullied_Spy
Unsullied_Spy's Avatar
12.09.2009, 02:18 PM
Parallel with bullet plugs is a little intereting because you have to get both sets of wires into the plug. Bullets are VERY easy to solder, though, and if you play around with different ways of stuffing your wires in there it should work but it'll take some messing with. I don't know the size of those Hyperion plugs, but 10 awg wire is pretty thick and you may have to get a little creative to get them in there. I run 5.5mm bullets on my motors and am switching my batteries over to them, and 10 awg wire fills them up pretty well.
EDIT: Depending on the size of those plugs, you may have to run both wires of your parallel harness into a single wire and do it that way.
