12.11.2009, 12:02 AM
I'm curious why they would put a 6mm shaft on it, they are basically building it for US and other future RC-M nut jobs and we all run 5mm shafts. If it has something to do with a helicopter needing a 6mm shaft or something, put that shaft on the Heli version with the ground down fins and give us the 5mm shaft! I'm not going to pitch a huge fit over it because I bought the motor before there was anything really known about it (said 5mm shaft on the chart, but it wasn't the only error) because I had faith in CC that they wouldn't do something so stupid as to give us the shaft like this.
12.11.2009, 12:39 AM
No worries guys, It's not hobbysh1tty were dealing with. Maybe a misprint warranty that still covers a grinded shaft and/or a easy rotor swap out?
How about 8mm mod 1 pinions? + with Mikes 8mm-6mm adpt.?
12.11.2009, 12:40 AM
Thats just beautiful...
12.11.2009, 12:41 AM
+1 on Unsullied_Spy
12.11.2009, 05:40 AM
45k rpm max is kind of a let down
Originally Posted by Semi Pro
Originally Posted by BrianG
i pwn nitro
12.11.2009, 06:53 AM
Originally Posted by Bondonutz
Drill press,emory cloth,lotsa beer for patience,Repeated oil dips.
Shouldn't take to long for a 1 mm ?
common bondo! we can do better than that!
i'd go with removing the rotor and finding some way to tail-stop it then machine with a carbide tip in the lathe.
12.11.2009, 11:19 AM
If yall are looking for 6mm bore pinions ......look here http://www.kershawdesigns.com/,,,scroll to the bottom of the page select "pinions" and again scroll down select "mod 1 pinions"and the 6mm mod 1 are at the bottom.
12.11.2009, 11:39 AM
My main issue is that I have a ton of 5mm bore pinions, and I only buy 5mm bore pinions cause I only buy motors with 5mm shafts...
I guess this 1717 motor can go in the 1/7 scale on road project I have, I was going to use a kb45 xl motor, and had mike enlarge the center of his 2 speed adapter to 6mm to fit that shaft. This has to have a custom made motor mount anyways... Sucks that I cannot use it with the lst (although I could if I use the 2speed adapter with the losi tin gears...)
Just a bit miffed that the info was wrong... Not much I can do about it now, my CC was charged yesterday and I am sure I will see the motor next week.
12.11.2009, 02:38 PM
I was curious what the RPM limit on these would be, I was expecting it would be 60,000 like the 15** motors since even their 2220 (or 2225, I don't remember) has a 45,000 limit. I don't plan to push it past 35,000 but it's always nice to know you have the headroom for safety or to push it faster if you so desired.
12.11.2009, 03:01 PM
Got mine today. Thing is massive!
Century Heli has 6mm mod 1 pinions in 9-11 teeth. Apparently pretty common for heli applications?
12.11.2009, 03:16 PM
Must be a heli thing, probably 600 sized. How good are those pinions? If they aren't properly hardened we'll wear those things out in no time.
12.11.2009, 04:10 PM
Sorry guys -- we just realized that the car versions of the 1717 were incorrectly listed as having a 5mm shaft.
About the 45000 RPM limit -- at 45000 RPM the magnets have a centripetal force of over 1500lbs/sq in on them (about 30,000 Gs -- seriously...) -- that's about the physical limit of the kevlar reinforced magnet structure. To go any higher, we would need to get a stronger material than Neo/iron/boron magnets. :(
We just don't know (yet) how to hold the structure together at above 30,000 Gs.
Patrick del Castillo
President, Principle Engineer
12.11.2009, 04:14 PM
Maybe you guys should contact NASA. They test that stuff out!
12.11.2009, 04:35 PM
Very thin carbon fiber tube will do the trick. It's been used in very high RPM motors.
12.11.2009, 04:48 PM
So we have to grind down our shafts, drill our pinions, or find new pinions?
