12.12.2009, 07:12 PM
As long as you run a pair of 2s lipos, hooked up as you would with a pair of stick packs, you will be fine. The evx runs the bec curcuit off 1 pack. It is a linear bec, so it is only trying to drop the voltage down from 7.2v to 6v (or whatever it outputs).
Wire the lvc to the bec side and you will be fine.
