motor for hyper sc10
hlb14
motor for hyper sc10 - 12.27.2009, 11:42 AM
Hey guys, im looking for your opinions on motor selection for a hyper sc10. It will have a mamba max pro and 3s LiFe providing power. My goal is to have a cool setup and good runtime (15-20min per battery) on a large 1/8 track in the summer. I have a vxl motor and was thinking about a novak hv5.5, but since the mmp is on b.o., i have some time and value your opinions. Thanks
jas21373
12.27.2009, 11:53 AM
what about a the New 1400 series motors from NEU,they 36mm cans http://www.neumotors.com/Site/1400_series.html
rootar
rootar's Avatar
12.27.2009, 01:24 PM
the 1409 1y or 1509 1y would be a perfect motor for the truck
hlb14
12.27.2009, 01:54 PM
ok thanks, those look like what i am looking for
asheck
12.27.2009, 03:18 PM
I say the hv 5.5 would do great, not that there is anything wrong with the Neu's. But why not Take advantage of the sensored esc, and they cost 1/3 as much.
rootar
rootar's Avatar
12.27.2009, 03:47 PM
yep they would also work very well.
12.27.2009, 07:08 PM
My vote is for a 1509 w/the kv depending on set up. I have a 1509 3300kv running in my crt.5 on 3s and it is perfect
hlb14
12.28.2009, 12:06 PM
is the differance between the 1409 and 1509, other than size, torque? am i correct in thinking the 1509 has more torque?
ta_man
12.28.2009, 01:58 PM
I'll second that. I'm running a HV7.5 on 3S with a Havoc 3S. Truck is fast, motor barely warm, ESC cool.
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
12.28.2009, 02:12 PM
i have plans for my slash...
even cooler temperature setup than this (so that means it's gonna be like anti hot? since ^ setup is already cool?)
i hope no one beats me to it...... they said i was mad...but i'll show them, i'll show them ALL MWAWAWAWAWAHAHAHAHAHAHAHAAA
asheck
12.28.2009, 09:00 PM
So, it's gonna run so cool, you can use it as a beer chiller when your done driving. :D
jas21373
12.28.2009, 10:08 PM
1400 shares the same rotor as the 1500 series but has a diameter that is just over 36mm. power output would be marginal ,you won't notice the difference
hlb14
12.31.2009, 08:24 PM
do you think the new 1512 1.5y 1800kv motor would respond well to 2s or 3s lipo??
12.31.2009, 08:38 PM
That's not even 20k rpm on 3s. If you gear high enough to have decent speed, you might get cogging on startup as the ESC tries to find rotor position. A sensored system would tolerate this better. I would get a motor with a kv of ~3000 (for 3s) or 4500 (for 2s). Low kv isn't always best - it's about matching the kv with the voltage.
hlb14
12.31.2009, 09:08 PM
ok, thanks, sometimes i get these wild thoughts in my head and need you guys to set me back on the right track, i have decided to stick with lipo instead of jumping to life... thanks again brian
