t-maxxracer32
t-maxxracer32's Avatar
12.30.2009, 02:35 AM
Originally Posted by jokerjustin View Post
the red rings on xboxes are related to components overheating.. do a quick search on youtube and theres step by step walkthroughs on how to fix it... the chances of your harddrive going bad are slim.
the components really arent overheating its more that the system is acting as if the cpu and gpu are overheated.
the 3 rings almost always mean you just have some type of cold solder joint in either the cpu or gpu chips.
now there are cases where things are actually overheated and burnt out but thats rare on a typical 360.
but like you said go on youtube and do one of the xclamp mods on it and it almost always works as long as the 360 isnt totally effed.
will cost 20 bucks at max for screws, washers, and the thermal paste
ive fixed a grip of 360s and havent failed yet with this fix.
if you havent gotten ahold of the other guy i can fix them also.
good luck!
