Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.14.2010, 08:32 PM
Did you manage to reverse the chassis Bondo? Looks to me like you could just spin the the rails ( chassis braces ) and it will work. Hope there's enough room for the servo!
Close but no cigar, I tried it many different ways but there was always something falling short, even flipped the chassis and no dice. I have decided to to stick to my original design make another lower chassis plate that will allow the motor to be closer to the side rail and off set the diff a little. This will allow the battery to ride on the side parraelle opposite of the motor. Hopefully it'll be balanced L-R and F-B this way, or close as possible ?
Also got some bad news today, My buddy whom owns the LHS didn't order my parts Tuesday as I was told he would. But they were ordered today and should have them Tuesday.
I'm stuck at a stand still till I get the 45t pinion because it will determin where the CD goes. Sooo everything is going in a box and I will start on another prodject. I have another LST2 that I just received my XXL chassis for and will swap everything over and check diffs and change shock oils. So I have something to do for Friday afternoon anyway.
