Semi Pro
Semi Pro's Avatar
01.17.2010, 08:48 PM
Originally Posted by mistercrash View Post
It would be nice to know if it can be done with the smart diff innards. If you try it, keep us informed of how it works. From what I know (and I don't know much) the smart diff uses the same diff case with the metal inserts and the same ring gear. I just don't know if the extra parts that go inside the smart diff would catch on the two screw heads for the posts that secure the output gear. If done well, the screw heads are well below the inside surface of the ring gear but I just don't know if that's enough for the smart diff mechanism to not catch or rub on them.
it can, i converted mine as soon as i got it back from you
you have to use the losi heavy duty diff cup, it all drops right in
