01.21.2010, 02:15 AM
More than one way to skin a cat guys... Not to say that Dan's stuff won't get the job done, but the finished product will speak for itself. I have owned a few of his chassis and motor plates and they will get the job done. Not on the same level as rcm products though. As for the motors, they will be feigao clones of some sort, so they will perform as well or worse. A xl 36mm motor with a kv around 1500 will be ok for 6s. I used a feigao 14xl on 8s and it did well. If you can swing the extra money get a castle 2200kv motor, and just gear down if you want to run 6s.
01.21.2010, 04:24 AM
well, there's only a couple things inside the cans. Perhaps, PERHAPS Dan addressed them. I'm 99% sure his "purpose built specifications" are external, ie: screw fastened front endbell, dark blue.
